i took pics of what im talking about can someone please help ty
new pic
And your question is...?
there is no number for me to sodier so what do i do
did you try sliding a hot razor blade under the pioneer sticker as well to see if there are other access points to see other contacts on the main board...it could be anyones guess why you don't have the correctly labeled R197 points...its a refurb, so maybe you have an n3 case around your n2 or something of that nature, or its a model that was initially manufactured to be used somewhere outside the U.S....if you look under all the stickers and don't find the R197 contacts, then i'm stumped
i got some good news thank you for your help really thank you i had to take the hole unit apart today and this is what i cam up with i see the two pins and im going to clean them thank soooooooooooooooooooooooo muck
it was under the pioneer sticker but it had plastic cover around it so i had to take it apart to remove it
