D3 Bypass problem
By agustinjr · Mar 14, 2007in Hacks/Mods💬 9 posts👁️ 2,279 views
Posted Mar 14, 2007 · 04:19 UTC#1
I did the bypass and everything seemed to be ok...no parking brake error message and video is all good - but I still cant get the address book in the navigation menu..any ideas? I've already reset (both with the engine off and while running) and still nothing...am i missing something?
Posted Mar 14, 2007 · 04:52 UTC#2
are you sure you did it correctly? Have you triedplaying a video past 15mph?
Sounds like you didnt do it correctly.
Posted Mar 14, 2007 · 05:28 UTC#3
i did everything per the instructions...the connection status in the navigation even shows that the parking brake is engaged...I do get video past 15 mph - thats what confuses me...If I didnt do it right - then i wouldnt get video right?
Posted Mar 14, 2007 · 12:41 UTC#4
Are there any addresses in your address book yet?
Posted Mar 14, 2007 · 22:34 UTC#5
just wanted to say thanks for the help...regrounded both wires and everything is all good...
Posted Mar 15, 2007 · 23:59 UTC#6
yup, knew it had to be a problem with the connections on teh bypass.
Posted Mar 16, 2007 · 04:52 UTC#7
when you ground the wires do you ground each one individualy or do you ground all three together with factory ground? also has ne1 put a switch on the pagking break or is that pretty much pointless.
Posted Mar 16, 2007 · 08:11 UTC#8
It doesn't matter whether you ground them together or individually, ground is ground. As for a switch, seems like a waste unless you are pulled over and want the warning screen up instead of changing sources
Posted Mar 18, 2007 · 00:34 UTC#9
It is probably best to ground them all together to make sure everything has the same potential difference. This also eliminates the chance of using a bad ground.
