raddd said:
hey i just bought a Z1 2day and i was wonderin wat if your car came with a dimmer switch? could u wire it to that or is that wat teh wire is for anyways?
It does not come with a dimmer switch. If you don't have an illumination wire and don't want to try and find a "parking lights" wire then you can hardwire a switch in to put the unit into "night" mode. Just wire the switch between the red and white wire (hook your red up to switched + as usual.) That being said if you post your car year, make and model we can probably find out what your illumination wire is.
Ducatiboy's unit does the following:
1. Bypasses security by pulsing the illumination wire on the z1 regardless of whether or not you have illumination hooked up on your cars side
2. Pass through the cars illumination signal 10 seconds after the unit boots up (and the bypass has been completed.)
3. The unit will work either with or without the cars illumination wire attached, but I highly recommend attaching it. I find the unit to be blinding at night without it.
