VSS Wire for 2006 Ford Freestar
By PDSchweitzer · Mar 14, 2007in Vehicle Specific Wiring💬 8 posts👁️ 4,335 views
Posted Mar 14, 2007 · 23:09 UTC#1
I am looking on where to find the VSS wire on a 2006 Ford Freestar
Posted Mar 14, 2007 · 23:38 UTC#2
Here are the pinouts for the connector.
1 (LG-VT) 18 Voltage supplied at all times (overload protected)
1 (YE) 18 Voltage supplied at all times (overload protected)
2 (GY-YE) 18 Accessory relay, switched power, output
3 (LG-RD) 22 Switch illumination, feed
4 (BK) 20 Ground
5 (YE-BK) 20 Power antenna module, switch, feed
6 * * not used
7 * * not used
8 (OG-LG) 18 Speaker, left front +
9 (GY-LB) 18 Speaker, left rear +
10 (OG-RD) 18 Speaker, right rear +
11 (WH-LG) 18 Speaker, right front +
12 (DG-OG) 18 Speaker, right front -
13 (BK-LG) 12 Ground
14 (WH-OG) 20 vehicle speed signal
15 (RD-BK) 20 Voltage supplied in Start (overload protected)
16 * * not used
17 * * not used
18 (LB-RD) 22 Auxiliary audio controls, steering wheel, signal
19 * * not used
20 * * not used
21 (LB-WH) 18 Speaker, left front -
22 (TN-YE) 18 Speaker, left rear -
23 (BR-PK) 18 Speaker, right rear -
24 * * not used
Pin 14 is listed as the VSS wire. It should be White and Orange.
Of course I guarantee the accuracy of nothing. :)
Sorry but I can't figure out how to copy the image of the connector itself.
Ken.
Posted Mar 15, 2007 · 00:17 UTC#3
if you cant get it at the radio, than try white/orange, black 40 pin plug under center console pin 4
Posted Mar 15, 2007 · 00:25 UTC#4
Pin 14 only is used/hot when a Reverse Sensor Option is installed from the factory..
Posted Mar 15, 2007 · 01:07 UTC#5
Interesting. On the diagrams that I looked at the VSS was comming from the ABS Control module to the radio. The connector to the Reverse Sensing System is shown as under the console.
One way to check it would be if your factory radio has the feature that increases the volume as you increase speed. It should be selectable in the radio Menu.
I installed the D2 in my Fusion and did not connect VSS as there isn't one. Unit works great without it.
Ken.
Posted Mar 15, 2007 · 01:12 UTC#6
thats what i said all along, you dont need vss with pioneer units
Posted Jul 15, 2007 · 17:22 UTC#7
Think this would work for a '04 Freestar?
Posted Jul 20, 2007 · 17:42 UTC#8
He's asking for me. When CC installed my Z2, they did great work but for some reason failed to connect the VSS wire. Now, I was reading in the Pioneer manual that the VSS wire connection is optional, because you can't access it in some vehicles, so I didn't think much of it. But now I'm wondering - did they forget to hook it up, or was there no way they could?
