Ok thanks for the replies. I have no choice but to burn with Windows. I'm using Roxio...so you say set it to ISO mode? I also have access to Nero...I should be using Nero instead apparently?
What's the limit on the length of the file names? Thanks!
It's not the problem using windows as the operating system but you can't use windows as the burning program. The only way it burns CDs is in a format that is not compatible. You can use Roxio or Nero, but you have to change the settings for the format when you burn the disk.
Just because disks are not free and they take a while to burn and go out and test... I have not tested every possible combination of parameters when it comes to this but when you are going to burn a disk, things that will make it as compatible as possible is what you should choose...
No Multisession, finalized,
Data Mode 1
ISO 9660
File names just 8.3 (and no weird characters or spaces, just numbers and letters)
Simple disk label, nothing fancy
I don't know which ones of these you can "cheat" on, but if you do this and it's burned on good cd rom, it will be as compatible as possible. None of mine ever failed.
