D3 CD-BTB100 REVIEW
By VBLUE42 · Mar 15, 2007in General💬 18 posts👁️ 4,968 views
Posted Mar 15, 2007 · 04:53 UTC#1
Has anyone actually put the cd-btb100 bluetooth module to good use with the D3 yet? What i would like to know is: did it auto connect to your phone when you turned on the unit and does it give the annoying echo that other units have.
thanks
Posted Mar 15, 2007 · 08:41 UTC#2
I cannot get it to autoconnect. Only have had one complaint on echo out of hundreds of calls
Posted Mar 15, 2007 · 15:45 UTC#3
Mine autoconnects to my sprint samsung M500 phone. However it will not import my phone book. It would of been nice but I don't mind because I can usually recognize who is calling me by thier number.
Dan
Posted Mar 15, 2007 · 19:52 UTC#4
mine isn't auto connect, i gotta go bluetooth and hand free on my phone before it connects, but i can import my phone book no problem, phone is Sony Ericsson P910i
Posted Mar 15, 2007 · 20:06 UTC#5
Any of you guys have a razr v3 that wont autoconnect?
Posted Mar 15, 2007 · 20:56 UTC#6
I HAD a Razr that would not connect with my Module. Correct me if I'm wrong but is it the software in the Module or is it in the Sysstem? I have a D2 with the 100 BT module and I got rid of the Razr because iIT would not auto connect. i tried other phones Slvr/L2 no go. I tried a Blackberry . Worked. I tried a small Nokia. Worked. I have a Nokie E62 that auto connects no problem. Hope this helps.
Posted Mar 15, 2007 · 21:14 UTC#7
I have D3 w/btb100
phone is samsung sync.
Auto connects no problem, incoming and outgoing calls no problem.
No phone book transfer.
It seems either people can transfer, but have hard time auto connecting, or they can auto connect but not transfer.
The btb200 is a different chipset, new software so hopefully that fixes it or back to crutchfield it goes!
Posted Mar 15, 2007 · 21:19 UTC#8
I have a Motorola ROKR E1 which will not autoconnect.
I can initiate the connection from the phone but sometimes have to reboot the phone.
Calls are clear without any echo.
I was able to push the phonebook from the phone, one entry at a time.
Most problems seem to be with Motorola phones.
Posted Mar 15, 2007 · 21:21 UTC#9
Samsung A900 Blade
Does not autoconnect, need to do it manually
Phone calls are clear, no echo
Phonebook does not transfer well, even contact by contact
Posted Mar 16, 2007 · 00:19 UTC#10
Samsung A900 Blade
Just curious what version of software is your A900. I have one and I'm waiting on the btb200.
Posted Mar 16, 2007 · 02:43 UTC#11
my a900 autoconnects fine...
Posted Mar 16, 2007 · 03:38 UTC#12
I have a samsung A640, it does not auto connect, calls are clear, no echo, even though I cant load the phone book, I can still use the voice dial feature that the phone has so I can just say the name of someone in my phonebook or the number and it dials, hands free! Easy to pair too!
Posted Mar 16, 2007 · 03:56 UTC#13
I'm not sure what version I have, the latest from what Sprint will give me when I try to update it.
Asianman, did you have to do anything special to yours to get it to autoconnect? When I try and send contacts to the AVIC, it has to search every time for AVIC - it's not listed under Trusted Devices. I can't figure out why.
Posted Mar 17, 2007 · 16:25 UTC#14
I have a razr. It will not auto connect, and I cannot transfer the phone book. I can, however, transfer one entry at a time. I wonder if the BTB200, which is due out soon, would make any difference, or if it's the phone that's out of date.
Posted Mar 17, 2007 · 17:14 UTC#15
Motorola phones has the WORST bluetooth and firmware.
If you want autoconnect to work, switch to Nokia...nokia has the best bluetooth i've used so far.
Posted Mar 19, 2007 · 04:51 UTC#16
Crutchfield said that pioneer took back w/e bluetooth kits were left, because they were having problems with them. So once the problems are fixed, they should be re-released.
Posted Mar 19, 2007 · 05:02 UTC#17
The CD-BTB200 is the re-release
Posted Mar 21, 2007 · 23:12 UTC#18
Anyone have any experience with a blackberry? im getting the 200 so im hoping it will be decent.
