Incoming Phone has "+1" in front, phone book can't
By powa · Mar 15, 2007in General💬 6 posts👁️ 1,138 views
Posted Mar 15, 2007 · 19:51 UTC#1
Got my D3 installed yesterday, very nice unit i have to say, just a few issue i am having with the BT, see if anyone can give me some input
I imported the whole phone book into the D3, but in Canada, all incoming call they have +1 at front, so let's say the phone # of John is (555)555-5555, the incoming call will be +15555555555, which in D3 it saids "unknown caller" but it's actually in the phone book list.
Does anyone know a solution to this? Also 1 more question, When driving at night, the Nav is fairly bright, i can go to V.Adjustment and change the Dim and bright option, but the next day morning i have to change the setting again since i obviously need the screen to be brighter in sun light. Is there a way to have it set in Night and day mode so when it's day time it makes it bright, at night time it keeps it dim?
Posted Mar 16, 2007 · 03:39 UTC#2
make and model of the car. Also did they hook up the ill wire off of the harness.
Posted Mar 16, 2007 · 04:37 UTC#3
Mercedes C320 Coupe year 2003, not sure if he hook up the illumination wire, but is it suppose to switch to day and night mode itself?
Posted May 17, 2007 · 08:41 UTC#4
Did you find a fix for this yet? i am having the same issue!
Posted May 17, 2007 · 11:12 UTC#5
The illum wire either isnt hooked up, or is connected to a wire that obviously isnt dimming the unit when you turn your headlights on.
Does your front ashtray have a lightbulb that turns on when you switch your lights on? If so, you can do as I did, and tap into the + wire for the ashtray lightbulb. That worked for me.
Posted May 17, 2007 · 13:00 UTC#6
Don't know about the ILL wire stuff, but the I had the same issue with my phone and the +1 coming up as "unknown"...
I went into my phone's phone book and added a 1 in front of all the numbers... Your cell phone is smart enough to only use the 1 and the area code if needed...
So, since all the numbers now are full 11-digits, now when I get an incoming call, it knows the correct caller ID info...
I actually called Pioneer about this and they said it was definitely a phone by phone issue...
This "fix" did the trick...
Good luck,
Mark
