D3 with dvd changer?
By onecleverthought · Mar 16, 2007in General💬 5 posts👁️ 976 views
Posted Mar 16, 2007 · 12:07 UTC#1
Does anyone know if it's possible to use a dvd changer with the avic d3? I have a VW 06 with the factory nav and center console cd-changer. My d3 is on its way and I was considering swapping out the cd changer with a dvd changer instead. Any thoughts?
--Curt
Posted Mar 16, 2007 · 13:40 UTC#2
Yes you can.
Posted Mar 16, 2007 · 15:05 UTC#3
OK, I found one made by pioneer, but I'm not sure if I would be able to install this vertically into my center arm rest console. It has a one din slot so I'm not worried about it fitting - I'm worried about it working. This is the changer:
http://www.pioneerelectronics.com/pna/v ... sComponent
Think it would work? It doesn't say anything about a vertical install (probably because there aren't many people interested in such an install).
Posted Mar 17, 2007 · 01:16 UTC#4
The installation manual does say that the unit can only be mounted at most 30 degrees from horizontal. Which means you can't mount it vertically.
Posted Mar 18, 2007 · 02:19 UTC#5
that sucks.
