speed sencer?
By new guy on the block · Mar 17, 2007in Problems/Troubleshooting💬 4 posts👁️ 911 views
Posted Mar 17, 2007 · 22:37 UTC#1
Hello all..... new member here !!!!!! Ok here it goes. I drive an 89 honda prelude with no computers...My speedo is a direct connect to the tranny ( replace the cable already) and the cruise control is vacume driven. Would anyone know how to make the gps in my newly refubed AVIC N2. That is without paying about $250 from pioneer? I already looked on EBAY etc...
I know someone knows the answer, and sorry if it has already been posted (i am new with searching blogs.....at 36 :oops: ) Although I am very mechanical and this will not be my first radio install. I have also done the bypass to the head unit already thanks to the help of this blog.
Thank you in advance for the help.
Posted Mar 17, 2007 · 23:36 UTC#2
im pretty sure it will be accurate enough without connecting your nonexisiting VSS. Should only be a couple feet off. The only times you really need it is if you have no gps signal.
Posted Mar 18, 2007 · 04:11 UTC#3
If you're that intent on hooking up a vss, try pm'ing Misfit. He might be able to get you an alpine speed sensor that'll work.
Posted Mar 18, 2007 · 23:55 UTC#4
Thank you very much guys. I thinks now that I know it will prob. be ok the way it stands I will try that first. If I find that no vss doesn't cut it I will pm Misfit. once again thank you.
