Speed Sense blue/white PCM
Notes: The PCM is located in the center console. The speed sense is located in a 32-pin plug.
Reverse Light green/black + driver fuse box, 10 pin plug
merry xmas
merry xmas
cntrylvr79 is the man! Wealth of info.
Thanks, I would not have known where to find my speed sensor wire and you saved me the trouble of having to run the reverse wire to the tail lights.
r123
No prob
I've got the center (trim) panel removed - I don't see any 32 pin plug. Am I looking in the wrong spot? Is the speed sensor behind the speedometer somewhere?
I'll see if I can figure this thing out - but any info you can offer is helpful. The reverse wire should be easy to find - I already located the fuse. I just need to locate the plug.
Thanks again,
R123
but no 32 pin plug is there. The reverse lights still appear to be where you said. Look - I know I'm probably being a pain in your ass
But I really appreciate & need your help.
Please let me know if you have any other ideas on where the speed sensor wire might be.
99 was the first year of a new gen of odysseys - so I'm wondering if the 2000 wiring info might be more accurate.
Thanks again,
r123
