Audi A4 Install Pics
By dascsh · Mar 19, 2007in General💬 20 posts👁️ 5,205 views
Posted Mar 19, 2007 · 00:49 UTC#1
Had the D3 installed with the Ipod adapter, XM NavTraffic, and backup camera.
Replacing a Kenwood DDX-6019 and the D3 has exceeded all my expectations.
Posted Mar 19, 2007 · 00:53 UTC#2
did you lose all those digital displays next to your tach
Posted Mar 19, 2007 · 00:55 UTC#3
Any photos on the install? Details please?
Posted Mar 19, 2007 · 12:54 UTC#4
I had the install done at Sound Advice and do not have any pics of the process.
I did lose the display that showed the station name which I have not had for a long time anyways.
Posted Mar 19, 2007 · 16:00 UTC#5
Very nice man, very nice.
I have a Z1 in my A4 (soon to be Z2, hah).
I see the AWE boost gauge there. What you got going on?
Posted Mar 19, 2007 · 16:29 UTC#6
Lots of mods including APR 1+, suspension, 19" Falkens, FMIC, S4 Brakes, exhaust and just redid the sound system.
I recently changed jobs and need my trunk space so I had a custom fiberglass box for a 12" sub. The front and rear speaker amp is in the side compartment, and the monoblock amp and capacitor are in the subfloor.
Posted Mar 19, 2007 · 16:55 UTC#7
Very very nice!
I have a 04 USP 1.8T, APR 1+, Neuspeed exhaust, test pipe, DV, etc.
My plan in the next 2-3 weeks is to do K04, Neuspeed Xtreme Turbo Inlet Hose, and some much needed maintenance. I would love a FMIC, but that may be after the K04, dunno, depends on time and price I suppose.
Posted Mar 19, 2007 · 17:18 UTC#8
that is a sic car. and i like the install too
Posted Mar 19, 2007 · 17:28 UTC#9
btw, what FMIC did you go with?
Posted Mar 19, 2007 · 17:47 UTC#10
Hey dude - this is exactly what I'm trying to pull off. Do you happen to have an itemized list of stuff they used for the install? I'm wondering if I need a cage....
Also - do you mind telling us how much the install was? I'm debating whether or not to do this myself, or get it done...
Looks awesome.
KB
Posted Mar 19, 2007 · 17:57 UTC#11
If you are looking to do the install of the Double-Din setup in a A4 it can be tricky...
If your car is single-din then you wont have the support for double-din units. Also your heat/AC controls wont fit down below.
a.
1. brackets needed.
2. sand the heat/ac to fit
b.
1. purchase the double din cage for a4 off ebay or some place?
2. purchase the heat/ac for double din a4 off ebay or some place
I have a Z1 in my A4 and it was a single din Audi Concert II when I started. I have custom brackets to hold the Z1 and sanded my heat/AC. Looks just as good, no problemo.
Posted Mar 19, 2007 · 18:15 UTC#12
AGRO-
Well it's factory. The factory radio is double-din sized, yes? It takes up the whole top of the dash. What I meant was that my dash kit needs to be modified to accept a double din radio.
Do you think there will be a cage in the dash I can re-use - or do I need a whole new one?
KB
Posted Mar 19, 2007 · 18:20 UTC#13
You probably have that Audi Symphony. Well either way, if it is double-din sized then you should be good to go. The only thing you will need would be a bezel to fill in the gaps around the headunit. Metra made a double-din for B6 A4, BUT it is meant for a single-din headunit and a single-din cubby hole. It's meant for going from double-din to single din. So, you will still have to fabricate a bezel. Luckily for our cars, a flat piece of ABS plastic shaped to fit works fine and looks great.
In a nutshell, you only need the bezel.
You are in a much better position than I was.
AGRO-
KB
Posted Mar 19, 2007 · 21:07 UTC#14
Below is the link to the kit I used. The middle piece can be removed so a double din will fit.
http://www.autotoys.com/x/cust/product. ... uctid=2465
The FMIC is the Evolution Racewerks Sport. It fits prefect behind the stock bumper with minimal trimming. It is a smaller FMIC that is best for a K04 or the smaller GTR eliminators.
I will check on the cost of the install and post it later today.
Posted Mar 19, 2007 · 21:15 UTC#15
I am trying to find a shop close to me to do the work. Eurocode tuning did my APR 1+, exhaust, etc. but those guys wont call me back. We'll see....
Posted Mar 19, 2007 · 21:30 UTC#16
Man up and get an S4
A4's are for wife's and girlfriends
Posted Mar 19, 2007 · 21:32 UTC#17
Aren't you supposed to be on an airplane to AsiaLand ©?
Fool....
Posted Mar 20, 2007 · 01:16 UTC#18
Hi Dascsh,
Great looking install!!!
I have also installed my AVIC-D3 this weekend and used the same bezel. However, I have not figured out how to secure the unit to the car. The manual says to use the brackets from the original radio, but there were none at my symphony radio.
Will any double DIN sleve do? What have you used besides this bezel?
Thanks,
Chris
Posted Mar 20, 2007 · 02:47 UTC#19
You will probably get the best response if you post on www.audiforums.com (I prefer AZ).
Hi Dascsh,
Thanks,
Chris
Posted Mar 20, 2007 · 02:50 UTC#20
*ORDERED*
K04 Turbo
Evolution Racewerks Sport FMIC
APR Turbo Inlet Hose
OEM Audi Timing Belt, Tensioner, Water Pump, etc. (full timing belt service)
*SERVICE GETTING*
Install of K04
Install FMIC
Install Turbo Inlet Hose
Timing Belt Service
APR K04 Flash (i'll call it Stage-II)
APR Test Pipe Flash
I'm excited!!!
My car should REALLY move!
