so has anyone installed a d3 in an 07 altima yet...my friend is almost done with the dash and I am picking up the harness and antenna adapter tomorrow...
any help would be appreciated
thanks
thanks
my friend did a Z1 in the 07 altima
do you have any idea how he did it?
dash kit?
wiring?
vss wire?(where is this)
reverse wire?(where is this)
where did u get the wiring harness from? do you have a part #
Any news on the kit and harness.
Bought kit and harness for D2 from Crutchfield. I think it's fairly similar for the D3, but not exactly sure. Hop over to Crutchfield and "Outfit My Car," and then you can choose vehicle harness and vehicle kits. I'm sure you will use the same double din kit I used, and the harness should be the same as well.
I would do it for you, but don't know if you have the Bose system with navigation, Bose without navigation, or regular factory radio.
i have the non bose system.
I also will need the dash cover. I am getting nervous that i wont be able to find it and ordered it though CF and got 15%.
Can you post a pic of your dash. The non bose has the dbl din I believe.
