2003 Subaru WRX VSS location
By Scooby328 · Mar 20, 2007in General💬 3 posts👁️ 2,286 views
Posted Mar 20, 2007 · 07:52 UTC#1
Hey All, I was wondering if anyone knows where to find the speed sensing wire on a 2003 Subaru Impreza WRX.
I looked it up and found the following:
Control Lever: 250-3421
Adapter: NOT NEEDED
VSS Wire: LOCATION 3- 3 CONNECTORS ON ECM MIDDLE CONNECTOR
VSS Wire Color: GREEN/YELLOW
VSS Pulse: 4000
VSS Tach Wire: LOCATION 16- AT COIL
Tach Signal Wire Color: RED
Brake Switch Positive: WHITE/BLACK
Brake Switch Negative: BLUE/YELLOW
But I'm unsure of where exactly the position is and where to start looking for it under the dash. Any help would be appreciated. I'm going to be installing a AVIC D3.
Posted Mar 20, 2007 · 10:35 UTC#2
green/yellow , ecm below glove box
SUBARU, IMPREZA, 2003, Speed Sense
On the non-turbo models the vss is in pin 10 of the 20 pin plug. On the turbo models the vss is in pin 1 of the 22 pin plug.
The vss wire is also found behind the instrument cluster in the 10 pin plug.
Posted Mar 21, 2007 · 01:31 UTC#3
Thanks I'll try to look there.
