No signal when I drive EAST
By George01v6 · Mar 20, 2007in XM/Sirius/HD Radio and Traffic Receivers💬 13 posts👁️ 2,622 views
Posted Mar 20, 2007 · 23:30 UTC#1
My XM works great except when I drive EAST in my truck. I have it mounted on the roof, front passenger side. It was the easiest place to put it, but it looks like I'll have to move it somewhere else to get better reception. Any ideas why this is happening? You can see the antenna fine from any side of the truck.
George
Posted Mar 20, 2007 · 23:57 UTC#2
What kind of truck. Try moving the antenna as you said.
Posted Mar 21, 2007 · 01:33 UTC#3
2006 Toyota Tacoma. I know they recommend putting it through the third brake light, but that's a pain in the butt. Just wondering if this is a common symptom for misplacement. Thanks.
Posted Mar 21, 2007 · 01:43 UTC#4
Don't drive East :lol:
Posted Mar 21, 2007 · 01:45 UTC#5
Yes it is common. Hey sportsfan he could drive east, just have to do it in reverse.
Posted Mar 21, 2007 · 01:56 UTC#6
Good thinking.
OP-
Once again we good people here at AVIC411 have solved all your problems 8)
Posted Mar 21, 2007 · 05:39 UTC#7
Guess I'll just take it off-road and head NE instead of East.
Posted Mar 22, 2007 · 04:06 UTC#8
Try centering your antenna on the roof. If you have it on the passenger side, the antenna is on the south side of your roof when you are going east (unless you are driving an english car, then forget about the rest of this post :) ). I believe that the antennas can use the roof to reflect some of the signals and thereby creating a larger antenna (sort of like a dish). Since most of your roof is "after" then antenna, it cannot reflect anything giving you a weaker signal.
Just my .02
Posted Mar 22, 2007 · 11:48 UTC#9
Its not really using it like a dish, its using it as a ground plane, but you make a valid point, the center would be the best place for it...just looks a bit odd with the wire running out to it..
Posted Mar 22, 2007 · 22:43 UTC#10
Yeah, you're right. But I figured that by using the word "dish", it would give most people a clearer picture. Hope it works.
Posted Mar 23, 2007 · 21:48 UTC#11
Well i tried it everywhere on my roof and got the same result. Crutchfield says the antenna could be bad so they are going to send me a whole new unit to try out. I'll let you know what happens.
Posted Mar 24, 2007 · 05:35 UTC#12
for free? Sounds like you hit the jackpot
Posted Mar 24, 2007 · 17:52 UTC#13
That's why Crutchfield kicks ass. Of course I have to send one of them back, hopefully it's just the antenna.
