XM +GPS Combo antenna?
By 05Stang-GT · Mar 20, 2007in XM/Sirius/HD Radio and Traffic Receivers💬 10 posts👁️ 6,414 views
Posted Mar 20, 2007 · 23:38 UTC#1
Anybody make a combo antenna for XM and GPS (would have to have to leads obviously) that will work with the Z1 and the GEX-P10XMT? Would make for a much cleaner install only having one antenna....
Posted Mar 20, 2007 · 23:56 UTC#2
Not really.
Posted Mar 21, 2007 · 00:01 UTC#3
Well that sucks...maybe I should start a company :P
Posted Mar 21, 2007 · 05:40 UTC#4
There is already another thread on this. Won't work, can't work, design isn't right for the type of antenna used.
Posted Mar 21, 2007 · 12:14 UTC#5
Um I dont think you understand what Im talking about...it most deffinatly could work, would just be two separate antennas in one housing with two leads....
Posted Mar 22, 2007 · 04:07 UTC#6
Hmmm.... go to radio shack, buy a project box, cut a couple of holes in it, put the antennas into it and glue it to your roof? :wink:
Posted Mar 22, 2007 · 23:46 UTC#7
Guess I misunderstood. You could mount two different antennas in one single housing, probably could work. I don't know if you would get any weird interaction when them being so close to each other. I was thinking you were meaning one antenna element, which wouldn't work since patch antennas are designed to work on a single frequency.
I'm guessing most luxury cars that have navigation and sat ready have that little fin at the back of their roof that contains both antennas.
Posted Mar 22, 2007 · 23:49 UTC#8
Shouldn't really be any interaction as both are just recieve only, although I know most GPS antennas are "active" in that they are fed +5V, not sure about XM though...
Posted Mar 31, 2007 · 14:20 UTC#9
Actually, there is no need because you can hide the gps antenna under the dash. Th gps antenna works just as well when hidden in the dash.
Ty
Posted Apr 18, 2007 · 13:24 UTC#10
I have both my XM antenna and my GPS antenna mounted side by side with no gaps between the two and there is no interferance or anything like that...
