i had a shop install an avic d1 but i noticed they didnt install my stock subwoofer on a 2005 expedition eddie bauer, i called them they say i cant connect it to my avic d1, is their an interface i can get to make it compatible with my avic d1, whats the model # where can i get it?? thanks
my oem sub is not working with my avic d1
70-5521. That comes with the sub harness.
so can i connect to the harness provided with the avic d1?? how? please help thanks!!
he just told you how... buy a Metra 70-5521 and use it... that's how
or here... 70-5522
yup yup
the metra 70-5522 plugs into the factory sub harness and into the d1's sub out. connect the blue/ white wires together, but put a resistor between the two. somewhere between a 2.4 and a 3k
im a newbie so when you say connect the resistors to each one of the cables what do you mean by 2.5 to 3k?? sorry ![]()
the value of resistance
Does the resistor technique work on any vehicle? The reason I ask is my mustang I has a different voltage between stock an aftermarket so there is a pop on turn on/off. Would the resistor fix that?
yes, the 3k is what i use on fords to eliminate the pop
and do the these have to be soldered??
it would be best
REally? I thought wire nuts were the best.
yup
