Okay, this is a bit wierd so I hope someone has seen this and knows a solution.
2006 Ford F-350 with steering wheel audio controls, Avic D3, and of course the PAC SW-PS adapter.
Everything functions perfectly until I turn on the trucks lights and then I loose the volume control on the steering wheel. "Next" and "mode" functions continue to work just fine, but the volume control becomes MIA. Turn the lights off and all is well again.
I do have the illumination connected so the radio dims at night, but why the interference between the dimmer and steering wheel controls? Is this an issue with the PAC adapter or programing? Some weird Ford issue? Would it be best to avoid the factory dimmer wire and source this from the light switch instead?
