No ringing when making calls with ND-BT1
By snacktrack · Mar 22, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,470 views
Posted Mar 22, 2007 · 03:45 UTC#1
Hey guys, I would like to throw this out there. I just installed a Z1 with a ND-BT1. When I make a call, I do not hear any ringing through the speakers when placing a call. Not only this, by the time I hear something the first "hello" or beginning of someone's voicemail is cut off. Its extremely annoying!! Does anyone else have this problem?? I have a Samsung t509 which I had hooked up to a Motorola IHF1000 handsfree kit which never had this problem. Any ideas?? Thanks in advance guys.
Posted Mar 22, 2007 · 17:53 UTC#2
I have this problem as well. I have a Samsung SGH-D807 with service through Cingular. So far I have no idea how to change this, but would love to be able to fix it.
I posted something about this a while back and there was at least one other person who had the same problem.
Posted Mar 22, 2007 · 18:21 UTC#3
Sounds like maybe its a Samsung thing....
Posted Mar 23, 2007 · 00:35 UTC#4
I would say its a Samsung thing, however, I just took out a Motorola Bluetooth handsfree kit when I put the Z1 in, which did not have this problem.
Posted Mar 23, 2007 · 00:45 UTC#5
Guess what I meant was sounds like its a samsung/ND-BT1 thing....
Posted Mar 23, 2007 · 13:44 UTC#6
Dialing from the phone itself or from the headunit. If I dial from the headunit, I get the rings and all. If I dial from the phone, I don't get something until the phone connects the call. I am using the HTC Wizard or otherwise known as the Cingular 8125.
Posted Mar 23, 2007 · 14:14 UTC#7
I have the same phone (8125) and your right it doesn't wring if you dial from the phone...
Posted Mar 24, 2007 · 05:42 UTC#8
I have the same problem with the Samsung D-500 with T-Mobile. I actually don't hear a ring when I have an incoming call either. The only way I know I have an incoming call is when my music goes off "0for no apperant reason". Then I get an incoming call message...but still no ring. If i drive without music on, I'm screwed :)
Posted Mar 24, 2007 · 20:55 UTC#9
Ah hah! Ok, I see now. I was using my phone to dial because I havent yet installed the new software update and wasnt able to dial from the numbers on the screen while driving. It does ring when I dial from the Z1. Now I just have to install the software update since I already have the two wires grounded. Thanks guys!
