I got a question about the new D3 aux input feature. Since it is different from D2 and Z1 I have installed, because to get Audio Aux input only on those you use the Aux Input Cable that plugs into IP-Bus slot behind the headunit, because if you use the video aux input you would get the blank screen instead of a proper blue background menu. But with this D3 it is available on the front dash with the mini jack audio cable or video.
So my question is if i plug in audio only (ipod) in to the aux in behind the unit will i get a blank screen since i dont have a video input? or would i be able to set it to normal background?
