Yet another noob n2 question
By Epstein · Mar 22, 2007in Hacks/Mods💬 5 posts👁️ 1,615 views
Posted Mar 22, 2007 · 12:43 UTC#1
First off I wanna say this site is incredible. The vast knowledge and amount of different mods is astounding........Ok enough blowing smoke up everyones a**
I have exhausted the search feature and done countless google searches and here is my predicament. I have a refurbished avic n2 and bought the circut pen as decribed. Well I pulled out my unit and found the sticker and peeled it away and low and behold there is no pins. It looks exactly like the Oversized picture another member has posted here (NVK). Now I am not going to be a hit and run member where I get my info and run I plan on being a contributing member and am currently a moderator on a popular Motorcycle website so I truly appreciate forums. Any Help will be greatly appreciated.
Brian
Posted Mar 22, 2007 · 14:44 UTC#2
Actually, there was another guy on here who said exactly the same thing about his refurb unit. I forget exactly what he said, but it turned out the pins were either concealed or relocated near the location.
Posted Mar 22, 2007 · 15:10 UTC#3
did it require disassembly?.....any help is appreciated
Posted Mar 30, 2007 · 14:25 UTC#4
topic has been up over a week and no one can Help?
Posted Apr 03, 2007 · 10:59 UTC#5
I was following the other post from the guy who had the same problem....i can't give you details, cause I didn't have this problem, even though my N2 is a refurb....my guess is that you do have to (carefully) disassemble the outer case on your unit, and somewhere on the circuit board there will be 2 points labeled R197...the bottom line, it seems, is that the points exist, they just are not always directly under that hole (for whatever reason)....if you do this and the points are non-existent, than you prob. have another model in an N2's case
