Help Programming the PAC SWI-PS Please
By ggolamco · Mar 22, 2007in General💬 4 posts👁️ 871 views
Posted Mar 22, 2007 · 17:45 UTC#1
Hi all,
I was wondering how much customization you can do for the steering wheel buttons using the PAC SWI-PS. For example, right now when I am using the radio, the "up" and "down" buttons on my setup will scan the frequencies. I would much rather have it switch between my 6 preset stations. Is there any way to do this?
Posted Mar 22, 2007 · 18:03 UTC#2
I don't have the Pac SWI-PS instructions in front of me, but yes, you can do that.
When you program the SWI-PS, you have 9 or 10 possibilities that can be outputted to the Z1. And you go through them and assign them to your steering wheel buttons. One of those is MEM (or maybe MEM + or something). But this will cycle through your presets. I can't remember which step in the programming it is. But you don't have to match your car's steering wheel controls to what they do.
I kept Vol up and down the same. My lincoln had a MEM button which I mapped to MEM up or Preset + or whatever SWI-PS calls it. I also had a MEDIA button on the steering wheel, I programmed it to be Track+ cause I wanted that instead.
As long as what you want to do is a possible output from the SWI-PS, you can program any steering wheel button to be anything outputtable from the SWI-PS.
Posted Mar 22, 2007 · 18:19 UTC#3
most of what ducatiboy said is dead on, with the exception of the mute button say in hondas, that require a resistor, you can program any button to do anything.
While programming you can simply skip the function (s) you dont want, so like the presets if i recall correctly come after the frequency tuning. but keep in mind that those buttons function differently in other modes, like playing a cd, so that will change the way the cd plays, and so on.
Posted Mar 25, 2007 · 01:59 UTC#4
Thanks so much guys! Guess it's time to pull out the manual :-)
