Reception?
By slicknick · Mar 24, 2007in XM/Sirius/HD Radio and Traffic Receivers💬 9 posts👁️ 2,546 views
Posted Mar 24, 2007 · 08:35 UTC#1
I just got XM with my D3 and when I pull into the garage it goes out completly. As soon as I pull out it's "verystrong" signal
I have it mounted on the top of the windshield in the middle.
Same for small bridges, overhangs, etc
Is it supposed to be this bad?
Posted Mar 24, 2007 · 10:51 UTC#2
Do you understand the concept of satellite signals? If not, return your whole setup now because GPS is the same way. coocho!
Posted Mar 24, 2007 · 12:12 UTC#3
So this is normal, thanks for the smart A$$ remark...I appreciate it.
Posted Mar 24, 2007 · 13:04 UTC#4
do you really need to listen to xm in the garage? :roll:
Posted Mar 24, 2007 · 13:11 UTC#5
Its not necessarily that bad everywhere. I live in Lincoln, NE and it gets blocked by the high rise buildings downtown. But when I went to KC, MO I got signal everywhere... Even inside of the parking garage! Some larger cities have repeaters set up; or at least that's what I've been told.
Posted Mar 25, 2007 · 13:55 UTC#6
Yep, here in Montreal, I was pleasantly surprised as my radio came back "on" as I was driving through a tunnel. Depending on your unit, you might have an "antenna aiming mode" and it should give you the signal strength of the satellite signal and the repeater signal.
As already mentioned, your satelite signal can be easily blocked by a structure overhead (such as a bridge) or beside (such as a building). However, GPS, seems to be more resilient and will not lose the singal as easily (although, I don't think it will stand up to a garage).
Posted Mar 25, 2007 · 14:01 UTC#7
Well if you're in the garage with the car running, give it a few minutes and you won't even notice that your radio isn't playing.
Posted Mar 25, 2007 · 15:40 UTC#8
what I normally do is say my fellow coocho, that way you get less back talk out of the coocho.
Posted Mar 25, 2007 · 21:31 UTC#9
hahaha wtf? maybe you should go back to being the aznsmartazz LOL!
