Cannot get custom images to load
By Jeffola · Mar 24, 2007in Problems/Troubleshooting💬 9 posts👁️ 1,576 views
Posted Mar 24, 2007 · 18:08 UTC#1
I have created both a CD-R and a CD-RW with at least 2.0mb of data on them. The unit tells me there is no pictures folder. but, aha there is.
Any ideas?
Posted Mar 24, 2007 · 18:21 UTC#2
What software are you using to burn the disc?
My first attempt failed, using drag and drop w/ Vista's built in burning software. I downloaded ImgBurn and my D3 recognized the image files.
Posted Mar 24, 2007 · 18:36 UTC#3
Windows Vista! You think thats it? Keep in mind, I am using a CD-R with no other files, just the /pictures directory (like it says in the manual)
Posted Mar 24, 2007 · 18:48 UTC#4
It turns out, that you cant use the Vista OS to burn. I used the Roxio suite and it worked flawlessly. Thanks for jarring my brain inthe right direction.
Jeff
Posted Mar 24, 2007 · 18:52 UTC#5
yeah i was going to suggest a burning program like nero, because you cant use windows to burn things.
Posted Mar 25, 2007 · 16:17 UTC#6
I created a custom boot screen, but it's cropped on both sides. Is this normal, or is there a way for it to fill the whole screen?
Posted Mar 25, 2007 · 16:30 UTC#7
500 X 240
Posted Mar 25, 2007 · 18:43 UTC#8
yeah make sure your pictures are resized to 500x240. This will fit any screen with the 16:9 ratio.
Posted Jan 11, 2008 · 03:31 UTC#9
I sized my photos according the the pixels listed in the manual as the screen pixel numbers in each direction. (136 x 72 mm) or whatever the pixel size ratios are in the spec sheet...worked good, stopped the cropping problem perfectly.
Also, read p.66 of the AVICD3 manual.
