Better Navigation?
By desotelle · Mar 25, 2007in General💬 13 posts👁️ 2,073 views
Posted Mar 25, 2007 · 21:28 UTC#1
Has anyone using the new Z2 notice better accuracy. Seems like one of the biggest complaints about the Z1 was it was off target quite a bit. What's peoples actual experience with the new nav software.
Posted Mar 25, 2007 · 22:08 UTC#2
I have not seen any difference.
Posted Mar 25, 2007 · 23:07 UTC#3
I talked to tech support yesterday to find out when the upgrade would be available. He said June. I asked him if it would fix the horrible navigation and he said in a not so pleasant voice, I wasn't aware anything was wrong with it. I proceeded to tell him that a friend of mine has a cheap garmin and it kicks pioneers ass. He told me that the upgrade was nothing but a map upgrade and didn't have anything to do with navigation improvement because there was nothing wrong with it anyway. I'LL TELL YOU ONE THING PIONEER IF IT DOESN'T YOU CAN HAVE YOUR PIECE OF SH!$ BACK AND STICK IT WHERE THE SUN DOESN'T SHINE !!!! When the darn thing wants to take you twenty miles south when you want to go north and then takes you to an empty parking lot instead of a restaurant and then they tell you there is nothing wrong,it really gets my blood pressure up.
Posted Mar 25, 2007 · 23:46 UTC#4
I see that.
Posted Mar 26, 2007 · 00:00 UTC#5
If you know where your going, why are you using a GPS?
Posted Mar 26, 2007 · 00:16 UTC#6
I have experienced that more than a few times.
Posted Mar 26, 2007 · 02:12 UTC#7
From what I am reading, it seams the old software gave directions to general areas (a group of house addresses for example) And the new software had coordinates for specific locations. Seems to me that would improve on it's accuracy.
Posted Mar 26, 2007 · 02:34 UTC#8
Never had a z1, but I have seen a few flaws with the map on my z2. It shows me a street over than what I am really on. However, when this occured, i was in an area that had many streets.
Posted Mar 26, 2007 · 03:28 UTC#9
Navigation takes time to calibrate too. If you have a Z2 in already, chances are good its not completely calibrated yet
Posted Mar 26, 2007 · 12:19 UTC#10
The Z1 navi could be better. I'd say mine is right 90% of the time, but when it's wrong, it WRONG. LOL When I have mine set to return home, it tells me to get off on the wrong exit. I'm 90B, and the Z1 says 90A. When I get off on 90B, the Z1 shows me driving through a field and then figures out I'm on the road. It then tells me to turn right when I should turn left and keeps telling me to make U turns for about a half a mile when it finally gets its brains back and recalcs the route correctly.
The POI database is also extremely poor in my area. Rarely is the address correct it takes me to. It's usually 1/8 to 1/2 a mile off from where the POI really is. This issue is mainly in my area though (Central Ky.) The POI database works fine when I'm traveling.
Posted Mar 26, 2007 · 14:12 UTC#11
what I did was change the POIs to the correct location via their modify destination, for all the POIs I have noticed that were off.
Posted Mar 27, 2007 · 01:00 UTC#12
Because when I don't know where I'm going I want to be able to trust it.
Posted Mar 28, 2007 · 20:44 UTC#13
i didn't know you can do that......how'd you do it....
