2 channel amp for front speakers=no sound from rear!
By BenJammin · Mar 26, 2007in Problems/Troubleshooting💬 13 posts👁️ 1,597 views
Posted Mar 26, 2007 · 01:55 UTC#1
Hey everyone
i had a question
i have the Z1 and i installed a 2 channel amp, connected to the front speakers, connected to the "front out" RCA's from the head unit. Now, i have no sound from the rear speakers. it's as if it becomes a "dead head" when it sensed the amp connected.
Does anyone have a fix? I'd like to run
Front Speakers = 2 channel amp
Rear Speakers = powered from Z1
Sub = ext bridged amp
Thanks for any tips!
Ben
Posted Mar 26, 2007 · 02:19 UTC#2
what vehicle is this? maybe you need to turn the factory amp on for the rears? which would suggest you have an amp already for the fronts your amping again maybe?
Posted Mar 26, 2007 · 02:20 UTC#3
are you sure you just cant hear them over the amp? try unplugging your rca's and turning the volume up to see if they are actually playing
Posted Mar 26, 2007 · 02:44 UTC#4
2003 f-150 harley..no factory amp.
i left out a detail. up until today i had been running the fronts and rears off of the head unit without issues. Not until i plugged in the amp did the rears quit.
i did pan front to rear to be sure the rears were not working.
thanks
Posted Mar 26, 2007 · 02:49 UTC#5
check the rear speakers to make sure they are good still, maybe when you installed the amp for the fronts they blew, or you disconnected the wiring along the way... or .. or ..
Posted Mar 26, 2007 · 14:57 UTC#6
Has anyone out there connected an amp of any kind to the Z1 system?
Posted Mar 26, 2007 · 15:24 UTC#7
yes
Posted Mar 26, 2007 · 15:51 UTC#8
yes
Me too...
Posted Mar 26, 2007 · 15:53 UTC#9
did anyone connect a 2channel amp to your front only speakers, leaving the head unit to run the rears?
:D
Posted Mar 26, 2007 · 18:00 UTC#10
yes. its someting your doing. or unit is bad.
Posted Mar 26, 2007 · 18:40 UTC#11
got it! that's what i needed to know
I'll let you guys know what i figure out
Posted Apr 02, 2007 · 14:53 UTC#12
hook all of the speakers up to the amp.
Posted Apr 03, 2007 · 04:26 UTC#13
yeah
