can you help me with the location of the vss and reverse wire on a 2006 Scion tC
Posted Mar 27, 2007 · 01:08 UTC#1
Speed Sense purple ECM, 2nd plug from top, pin 17
The ECM is behind the glove box.
The VSS wire is also yellow in the radio harness
Reverse Light pink + top of fuse box, 14 pin plug, pin 2
I am trying to find the location and color for the VSS and backup wires on a 2002 F-250 SD W/ powerstroke (if it matters).
vss- grey/black. if not at radio harness go to to abs module on drivers side engine compartment
reverse-black/pink back of fuse box
Thanks for the help! This is a great site.
OK I thought the wire would be easy to find but I cannot find it. Does anyone have any other guidance on what to look for? I found the backup wire but can't find the VSS. ANy help on what the connector looks like or something would be appreciated.
