Hi,
I have a AVIC N2 for about a year, it was working great since two days ago. For not reason, the joystick from the faceplate is not working from left and right but it's ok up and down and when i push it. So I cannot use the joytick to change CD track or adjust the radio station.
I was thinking that by reseting the unit, i may fix the pb but of course nothing good append. After reset, the unit when back to factory configuration, than i tried to adjust angle of the screen, but nothing. The two button + and - to adjust the angle are not working too. I didn't checked before resetting the unit but i believe that these 2 angle buttons were not working before the reseting.
I did opened the unit and check the little cable under the unit, linking the front panel to the main board. I unplugged it and put back it back but didn't get any luck.
I don't believe that the pb come from the faceplate but I can be wrong.
If anyone have any idea what can be the problem, or which part need to be change ![]()
