Help! DVD turns off after 10 mph
By DoubleURX · Mar 28, 2007in Problems/Troubleshooting💬 7 posts👁️ 1,268 views
Posted Mar 28, 2007 · 05:07 UTC#1
I installed the AVIC-D3 into my Subaru WRX, and I also followed the instructions for the parking brake bypass and moving the mute wire. However, the dvd will work if i drive below 10-15 mph, but the dvd will not show on the screen if i drive any faster. I still need to install the VSS wire, do you guys think that the VSS wire is what is causing this problem, or do you think i have a different problem?
Posted Mar 28, 2007 · 05:25 UTC#2
no, you have to bypass it as instructed, obviously its not done 100% correctly, check it and youll probably find your problem there
Posted Mar 29, 2007 · 03:42 UTC#3
yeah the bypass is definitely not hooked up correctly. Make sure that mute wire you relocated is securely in place and touching the pin.
Posted Mar 29, 2007 · 03:49 UTC#4
2 words installer error
Posted Mar 29, 2007 · 04:15 UTC#5
Unrelated Question:
Does by-pass affect the muting function of bluetooth phone or any other 'muting' related function (or anything at all). I would believe it would affect something since its a 'mute' wire???
Thanks.
Posted Mar 29, 2007 · 04:40 UTC#6
No, mute is for like a parrot bluetooth
Posted Mar 29, 2007 · 04:48 UTC#7
yeah mute is only for an external bluetooth like previously stated (parrot) this has nothing to do or wont interfere if you have the pioneer bluetooth adapters
