subwoofer not working with cd, library, only fm
By tomedekid · Mar 28, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,067 views
Posted Mar 28, 2007 · 18:02 UTC#1
i just swapped the z1 into my new truck and the subwoofer does not work in anything but fm? i checked all the wiring, everything is fine. after speaking with pioneer, they assume the unit must be faulty. just wondering if anyone has had the same issue.
thanks
Posted Mar 28, 2007 · 18:28 UTC#2
did you check to see if tha auto ant is set for power if its not it will only send remote signal when radio is on
Posted Mar 28, 2007 · 19:33 UTC#3
Are you sure you hooked up the amp remote to the Z1s sys remote wire and not the autoantenna wire?
Posted Mar 29, 2007 · 04:04 UTC#4
Nope as stated above, install error. You've got the blue wire going to where the blue/white wire should be.
Posted Apr 20, 2007 · 06:26 UTC#5
i will double check. thanks for the prompt replys. you are lifesavers!
