i have a 2006 passat and my radio will not turn off help
By los21 · Mar 29, 2007in Hacks/Mods💬 7 posts👁️ 4,296 views
Posted Mar 29, 2007 · 13:53 UTC#1
i cant get my radio to turn off becuase my car stays powerd all the time when the key is out of the ingintion so the radio stays on and it is killing my battery in my car please help me to get this to cut off is there a bypass tht i can cut it off when the car is off please help me asap my email adress is [email protected]
Posted Mar 29, 2007 · 13:58 UTC#2
In the future get rid of the bold. It's annoying. You have run a wire from the ignition to the red wire of the avic so it'll turn off when the car is off.
Posted Apr 06, 2007 · 13:46 UTC#3
This is correct, you can tap off of the blue fuse (15amp) on the drive side last fuse towards the bottom, it is for the wipers.
I have a 07 and this is how I did it.
Good Luck.
Posted Apr 08, 2007 · 03:01 UTC#4
If your car has steering wheel controls (and I think all Passats do,) you can also get a PAC SWI-CAN adapter which will not only let you use the steering wheel controls with your D3 but also gives u a switched 12V without having to run any kind of wires to the fuse box. http://www.pac-audio.com/products/produ ... 0Interface
Posted Apr 08, 2007 · 06:18 UTC#5
that sounds like it would work great.
Posted Jun 03, 2007 · 01:33 UTC#6
I had mine installed with the SWI-PS and SWI-CAN and that solution works great. You maintain the steering wheel controlls and the red 12V ACC wire controlls the AVIC just like the factory Stereo.
Instructions are VERY easy once you read threw, just follow the instructions that came with the SWI-CAN module. The others can be kinda cofusing.
Just a couple notes:
SWI-CAN works great in my VW, but you should look at the Soundgate CANPULSE. This gives you steering wheel controlls AND a VSS solution all in one. Also, make sure you figure out some way to attach the illumination wire. I have to bring mine back and have it connected since my installer didnt do it the first time.
Posted May 18, 2008 · 00:08 UTC#7
With the SWI-CAN installed what interfaces were you able to retain. What I mean is in my 06 Passat the multi function display in my instrument cluster allows me to display information about the audio: what I'm listening to currently, and volume, and it also allows me to switch the screen to display the navigation. Does the SWI-CAN allow both those things?
