All verizon phones (that I'm aware of) will NOT autoconnect with the BTB100.
That means if you want to connect your phone, you must follow these steps:
1) Register your phone (only done once per phone, forever)
2) Turn the phone and D3 on.
3) Touch 'BT-Tel', it will say no connection.
4) Touch 'Menu'
5) Touch 'Function'
6) Touch 'Connect Phone'
7) Touch 'Direct Connect'
Touch the name of the phone you want to connect.
After that your phone will be connected until you turn off the car.
Alternatively, you could set the BT on your phone to be 'visible' immediately before turning on the D3. If you do this, the D3 WILL autoconnect (meaning you don't have to touch anything on the screen to connect), but Verizon phones will only stay 'visible' for 60 seconds. After that, you've got to go through the above process.
Apparently Cingular RAZRs will autoconnect with the BTB200 (but not BTB100), no word on the Verizon phones.
