Speed Sense green 4 PCM
Notes: The PCM is located in the passenger kick panel
merry xmas
merry xmas
Thanks for your info on finding the VSS hookup, but it looks like the installer didn't hook up the ILL wire either so my radio doesn't change when the lights get turned on any idea where that wire is?
Thanks again
Kraljsved
Gray at the radio harness.
thanks again I'll let you know how everything works out, you're the man
Hey thanks for the previous help, but when I went to look at the PCM today it had three wire plugs going into it. The first one on the left was Red and the other two were grey. The first red plug has 3 or 4 green wires on it but none of them were in position 4. Is there a difference in wiring between the STS that you quoted and the SLS that I have?
Nope, I quoted an SLS, but for some reason I had sts on the brain.
