04 Cadillac SRX
By tmiles2246 · Apr 01, 2007in Vehicle Specific Wiring💬 3 posts👁️ 901 views
Posted Apr 01, 2007 · 01:24 UTC#1
I've searched and am looking for the illumination, VSS, Brake and reverse wires for a 3.6L AWD 04 SRX. Thankyou,
Posted Apr 01, 2007 · 15:52 UTC#2
Reverse Light lt. green + LR fusebox near L side of rear seat
Brake Wire white + driver kick, harness to rear
Speed Sense brown instrument cluster, pin 2 or ECM
The ECM (Engine Control Module) is on the passenger side of the motor under the cover on the 3.6L, and it is on the left frame rail below the driver side headlight on the 4.6L.
On the 3.6L, VSS is in pin 22, connector 2. On the 4.6L, VSS is in pin 28, blue plug.
Also found at the radio harness, on some models.
Parking Lights+ purple (L), brown/white ® + each kick, harness to rear (use either one)
Posted Apr 06, 2007 · 20:57 UTC#3
Thank you for the info and your time....
