Someone told me that I can get the vss aire behinde the radio and on 13 pin harness where is the harness and is that true.I have a 06 nissan armada with a bose system
vss information
I got you on the other post. But it is the solid PINK on one of the harness' that came off the oem radio.
di you hook up the pac contoller and was that hard I was trying to find the 13 pin wire harness
I did have the Pac controller but something went wrong and it stopped working ( I will reinstall it after I get someone that is good with Soldering {I Suck}.) Keep looking it has 13 pins with 2 or 3 empty spaces. Go to the Armada forum and search PAC audio. Someone has a link to Club Titan with pics on it.
Try any of these, found conflicting info
Speed Sense RED/WHITE (AC) IN HARNESS AT REAR OF GAUGES
Speed Sense white/red 8P cluster or shift lock control unit
The shift lock control unit is behind the glove box, to the left.
Also found at the AV switch.
