Z1 play DVD Audio?
By Guest · Jun 09, 2006in General💬 8 posts👁️ 1,733 views
Posted Jun 09, 2006 · 15:32 UTC#1
well?
Posted Jun 09, 2006 · 15:54 UTC#2
No. The only current Pioneer that does play DVD-audio is the AVHP7800DVD
Anonymous said:
well?
Posted Jun 12, 2006 · 09:42 UTC#3
Yes it will lay some dvd audio i have three and it played 2 out of the 3
Posted Jun 12, 2006 · 22:02 UTC#4
If it played your DVD-A disc, it was actually playing the DVD-V audio track that most labels include alongside the high resolution version. The DVD-V track is plain PCM audio (44.1kHz/16-bit CD quality), whereas a true DVD-A disc can run as high as 96kHz/24-bit.
the only units that are able to play DVD-A are the AVH-P7500DVD, 7600DVD, and now 7800DVD.
Posted Jun 13, 2006 · 17:22 UTC#5
To add to this the Z1 will also think you are trying to watch a movie so unless you are stopped or your unit is "cooperative" you will not be able to change tracks or do much to what you are listening to unless stopped.
Posted Jun 13, 2006 · 18:45 UTC#6
what about mp3's on a dvd-r?
Posted Jun 13, 2006 · 19:52 UTC#7
The 7800DVD will play MP3s on a DVD, but no other units can.
