jsut wondering whats the easiest way to move the mute wire... or ways you guys hav done it... ive herd an eyeglass screw driver? anoy other options
How did you move your Mute wire?
Check out the flash gallery below in my sig.
I used a flat head screwdriver for eyeglasses. Any kind of small flat object would work though.
Mini eyeglass flathead screw driver, it had a very sharp tip and slid right under.
i used xactor knife. worked great.
I ripped mine out like an idiot...luckily nothing got messed up.
Ripping it out is not a big deal. If you break off the pin, you can always buy another one at radio shack and crimp it back on. No biggie. It's just easier to pry the plastic up a bit and pull it out. ![]()
Now, if some eager hacker can just get this notification screen to go away... ![]()
I pulled on it.
very carefully
I used the tip of a wood screw.
I am about 95% done installing the D3.
so far it works
I used a dental pick.
Let's see, I've
ripped em out,
razor blade
straight pick
tip of a screw
pin from another harness
etc etc
