Can you access rear view camera without being in reverse?
By tresx · Apr 04, 2007in General💬 4 posts👁️ 921 views
Posted Apr 04, 2007 · 04:52 UTC#1
Just wondering.....can you access the rear view cam through the D3 when you are not going in reverse (granted you installed everything per the manual)? I figured if you couldn't, I'd just tap the reverse lead to power the camera. Obviously this wouldn't be efficient if you CAN access the rear view camera while going forward. The only reason I'm asking is because the acc lead in my car is quite a b#%@h to get to.....thanks!
Posted Apr 04, 2007 · 04:56 UTC#2
Yes, go to MAP screen, then hit MAP a second time, this will give you your MAP view choices, select the last one.
Posted Apr 04, 2007 · 14:58 UTC#3
:D
Posted Apr 04, 2007 · 15:26 UTC#4
yup yup
