Posted Jun 10, 2006 · 17:35 UTC#1
On the GEX-P10XMT unit, is it the IP-Bus cable that tells the unit when to turn on an off? I just recieved mine and there is a supplemental correction sheet in the box that tells you not to connect the RED wire when the unit is attached via the IP-Bus cable. The RED wire is the one designated for the switched ingnition lead. Is this correct?
