Ipod noise
By mentalcase · Apr 04, 2007in Problems/Troubleshooting💬 13 posts👁️ 2,382 views
Posted Apr 04, 2007 · 19:58 UTC#1
I noticed today that my d3 has a slight whine when im listening to the ipod. At low volumes you can barely hear it but when you turn it up it is noticeable. It is annoying too. I dont hear it under any other input just the ipod. Any one else have this problem or a way to fix it?
Posted Apr 05, 2007 · 05:41 UTC#2
Just sat in my car for a little while to try and figure out where the wine came from. So if anyone has the same problem here is how to make it less noticeable. It seems to be caused by the ipod when it goes into standby with the backlight. If you keep the backlight on constantly then the problem is alot less noticeable. It may kill the backlight on the ipod, but i rather have no white noise.
Posted Apr 12, 2007 · 16:11 UTC#3
I'm having the same problem in a 2005 Ford F150 and can't get rid of the noise.
Posted Apr 12, 2007 · 18:13 UTC#4
Does the problem occur only when it's plugged in to the cigarette lighter and charging, or when it's running on battery power also?
Posted Apr 12, 2007 · 20:11 UTC#5
I'm using the CD-1200 iPod cable plugged directly into the back of the D3 and the noise occurs whether the charging function is turned on or off.
Posted Apr 17, 2007 · 23:26 UTC#6
Just got the d3 installed and on the way home I noticed a faint hissing sound when I was playing my ipod. It went away after I changed sources. When I went back it wasn't there. Then later I think it come back.
Posted Apr 24, 2007 · 01:16 UTC#7
Mine still has the whine/hiss. I really wonder what it is.
Posted Apr 28, 2007 · 23:24 UTC#8
Same problem, I feared this when buying the cdi200, as it has no ground. Will turning charge off eliminate this?
Posted Apr 29, 2007 · 05:14 UTC#9
Problem diagnosed and fixed. Mine goes away when you turn off the charging feature. Just have to remember to turn it on when listening to sirius.
Posted May 03, 2007 · 06:51 UTC#10
mine does it too it got really annoying to me, since i listen to my music loud haha, but the only way i found to get rid of it was to keep the back light of the ipod on all the time and the noise disappears. i was kinda disappointed because i dont want to mess the ipod up
Posted May 03, 2007 · 17:45 UTC#11
This worked for me...
Posted May 03, 2007 · 17:46 UTC#12
This also worked for me, Im going to start a new thread on this and request it be stickied.
