Installed D3 in my F150...Pix inside
By elchorizon · Apr 05, 2007in General💬 16 posts👁️ 4,917 views
Posted Apr 05, 2007 · 01:48 UTC#1
Took a few pix of my install in my F150..Thanks to all the members for all the info on this site. Did the bypass mod and installed the VSS ,reverse wire & camera. I placed the GPS antenna on my dash tray, I cut the rubber where the antenna sits so the GPS sits flat in the tray.
Posted Apr 05, 2007 · 02:05 UTC#2
nice job
hey destinydog, if your looking at this, your antenna is going to be directly under where his radar detector is, with the wire going between the two panels
Posted Apr 05, 2007 · 10:54 UTC#3
fine with me..your the boss!
where did you put the reverse cam?
Posted Apr 05, 2007 · 16:40 UTC#4
I did not use the Pioneer cam that I got, I used a infared round cam it was placed in the OEM location for a backup sensor.
Posted Apr 05, 2007 · 18:39 UTC#5
nice..i think i saw pics of this on f150online.com
very nice though!
Posted Apr 06, 2007 · 17:50 UTC#6
Thanks, yes im a member at f150online..
Posted Apr 06, 2007 · 18:01 UTC#7
are you getting a thump in your sub when you turn the d-3 on? that is if you have the ford sub
Dave
Posted Apr 07, 2007 · 06:11 UTC#8
Dave
Sorry, I dont have the OEM sub..
Posted Apr 07, 2007 · 11:57 UTC#9
Dave
The fix for that should be as simple as providing a 5-volt turn on lead instead of 12-volt. There are different ways of reducing the voltage but any decent stereo shop should be able to point you in the right direction.
Posted Apr 07, 2007 · 13:18 UTC#10
That camera is similar to the one I'm looking at. How is the pic quality, and if possible could you post them? Thanks!
Posted Apr 21, 2007 · 05:54 UTC#11
I have an AVIC Z2 in my garage and I plan to install it in my 2004 FX4 F150 this weekend.
A couple of questions:
1. Did you have any problems with the Satellite reception with the antenna placed on the dash, per your pics?
2. Are you able to view DVD while driving?
Posted Apr 21, 2007 · 17:35 UTC#12
Don't know about watching DVD whlie driving on the Z2, but the GPS satellite antenna works just fine underneath my dash. ('06 F-150.) I have an Avic D3. XM antenna must be located outside the cab because the reception isn't good enough under the dash.
Posted Apr 21, 2007 · 18:40 UTC#13
no bypass for the Z2 yet
Posted Jun 20, 2007 · 04:36 UTC#14
hey elchorizon, where in texas do you live? I live in san antonio and was looking for someone to help (i've never done it before) install my d3. MY email is [email protected] if you want to correspond through email.
Posted Jun 21, 2007 · 05:57 UTC#15
elchorizon- what color wire was the vss and reverse? also, where did you find them? thanks
Posted Jun 21, 2007 · 06:05 UTC#16
the vss wire is the gray/black wire in the factory ford harnes. you will prolly need to unwrap the wires to tap into it. i don't know where the reverse wire is, i think it is down along the driver side kick panel, but don't know which wire it is.
i have a 04 new body style f150
