I have a 05 avalanche and tring to locate where to attach the green wire for the pac swi-ps. their website shows a terminal "you could always reach over and turn down the volume" I was not amused. Please help!!!!
Problems finding the wire for pac swi-ps
thats great. doesnt your instructions give you the info?
the instructions were very general and does not say where the connector is located.
the connector is usually the radio harness
Here is the link to the Pac-Audio site for your truck. Says you need to connect the green wire to pin B31 (Lt. Green) in the steering column. I wouldn't count on B31 being light green, but it may be. The color of my wire it specified was incorrect. Just take a look at the pins and locate the correct one. Whichever wire is in that pin location is the one you want to tap in to. Make sure to cut the brown looped wire in the SWI-PS harness (step 5). Good luck. It's a little confusing, but works great once you get it.
Russ
I found it!!! i had to remove most of the dash and metal sheild to get to it, but i got it, thanks guys.....
