PAC SWI-PS need help programming for Hummer H2
By bullseye · Apr 06, 2007in Problems/Troubleshooting💬 1 posts👁️ 849 views
Posted Apr 06, 2007 · 04:09 UTC#1
I'm using a D3 and SWI-PS, installed by Best Buy. It seems they did the wiring right, but we unable to get the device programmed to work. I'm trying myself, and it appears to run thru the programming sequences properly. At the end of the sequence, I get 3 flashes, and 1 more flash for Version 1. Then my radio goes cranking full blast! The wheel buttons don't work. I've repeated the programming, and have the same result where it cranks the radio to full volume! ahhh
:shock:
I have a couple functions like mute that need to skip, so I use the program/mode button to skip it. Seems pretty straight forward, but I'm not having any luck. I called Crutchfield and they were unable to solve it. They are having me call Pac Audio direct for support, and if unable to resolve, then CF will send me a new device. Anyone run into this?
