Has anybody installed the D3 in a Audi A4?
By slimcubby · Apr 06, 2007in General💬 20 posts👁️ 4,622 views
Posted Apr 06, 2007 · 05:36 UTC#1
I need to know if it is going to be a dificult install and what adapters faceplates etc that I need...
Thanks!!
Posted Apr 06, 2007 · 11:40 UTC#2
search d3 install in audi a4, its there
Posted Apr 06, 2007 · 12:08 UTC#3
I am/will be doing a D1 in a A4 now.. Worked on the harness last night.
I am sure the D3/D1 installs are very close to each other
Posted Apr 06, 2007 · 16:22 UTC#4
If you could send me pics or info on all the items that were needed to make it fit in replacement of the stock unit that would be great! I just ordered the metal cage from pioneer so hopefully that is something that I needed lol.
Posted Apr 06, 2007 · 16:39 UTC#5
Do you have a BOSE system in the car now?
Posted Apr 06, 2007 · 17:01 UTC#6
Nope standard... but I did rewire all the door speakers and installed seperates. I currently am running the symphony II with a blaupunkt adapter to allow for rca outs.
Posted Apr 06, 2007 · 22:53 UTC#7
Hey dude-
I installed the D3 in my 04 A4 recently - there are some tips here that you will find useful. In addition to this you should know:
1. you will have to tap directly into a headlight lead to get the illumination to work - or use a workaround found here in the forum
2. if you buy the faceplate I did [search for a picture] you should cut off the ends of the tabs that lock it in place - if you don't you'll NEVER get it out again. In fact - the fit is extremely tight.
3. you WILL need an avic-d2 cage to do this install.
4. You can run the rear leads directly into the rear amp [most people say don't do this] and it will work and sound just fine - in fact it will sound AWESOME with a little fading and tweaking - the subwoofer will come alive
5. you should hold the antenna connection to the D3 with duct tape because it WILL come off during installation
6. with all said and done - you will love this unit in the car - it matches the lighting really nicely and rocks.
I installed the GPS sensor under the vent in the center of the dash [on top of the dash] and it works great.
Good luck !
Posted Apr 06, 2007 · 23:03 UTC#8
Do you have pictures or anything? Does the cage bolt to the faceplate? Also do I need to tap into the speedometer for the navi? Thanks!
Posted Apr 07, 2007 · 02:15 UTC#9
Here are some pics of my install. I do not know what was done as I paid to have it installed.
Posted Apr 07, 2007 · 02:35 UTC#10
If you have to do number 5 then the plug IS NOT plugged in all the way. The gps antenna plug locks into the avic. In fact it's a pain in the ass to remove.
Posted Apr 07, 2007 · 17:39 UTC#11
Actaully - I'm talking about the AM.FM antenna. Audis and VW's have proprietary plugs which require an adapter - and they are notorious for not fitting tight.
Yes - the cage fits directly into the faceplate and the whole assembly slides right in....
Posted Apr 08, 2007 · 00:54 UTC#12
My bad misred the post. Yeah the fm antenna can give you problems staying plugged in.
Posted May 22, 2007 · 00:15 UTC#13
A quick question regarding the post above, how do we remove the dash kit that is shown above? Ive got my unit out and i had an installer do it so ive got no idea how to go about removing it.....
Posted May 26, 2007 · 21:25 UTC#14
Hey dude-
Good luck !
What year is your A4? If its an 06, is it possible to tap the VSS or do you need a CAN-BUS adapter?
Posted May 27, 2007 · 00:18 UTC#15
......I installed the D3 in my 04 A4 recently .....
Posted May 29, 2007 · 01:28 UTC#16
I just did a D3 in my '04. If any one has any questions feel free to ask. I saw that the '06 might still have a VSS wire.
Posted Sep 03, 2007 · 05:27 UTC#17
I was looking to add an AVIC to my 02 Audi A4. For those that have already done something similiar to this, does the info screen in the middle of the dash still display the song title / info? Did you need to wire anything different for this to work? Thanks!
Posted Sep 03, 2007 · 07:02 UTC#18
The screen does not work any more (just the top part). I was trying to see if I could interface it with the Pioneer via the ip-bus, but there was not enough info out there to see what could be done. It's probably not worth it anyway.
Posted Sep 06, 2007 · 13:06 UTC#19
I did an install of the D1 in my '02 A4. Just ask if you have any Q's
Posted Jan 28, 2008 · 03:07 UTC#20
My installer used a CANPULSE4 from Soundgate ($200-300) to get the speed pulse it needed for my 2008 Audi A4. He used the CAN45PIO adapter to connect it up to everything.
They say the PAC SWI-CAN + SWI-PS combination works a little better.
