D3 aknowledgement bypass
By gsj224 · Apr 06, 2007in Hacks/Mods💬 2 posts👁️ 1,466 views
Posted Apr 06, 2007 · 18:02 UTC#1
All -
Since the software of the D3 is not embedded on the circuit/within ROM, has anyone scrutinized the files on the DVD's supplied? There has to be a control file which is waiting for a response to this question at startup. Before I run off too much at the mouth has someone done this yet?
I was thinking along the lines of a kernal file bypassing network login within windows.
:idea:
Posted Apr 06, 2007 · 18:50 UTC#2
Good luck with that.
First you've gotta find out which file to hack
Second, you've gotta figure out what to hack the file with
Third, you've gotta recompile and re-burn.
Definitely worth a shot if someone is smart enough to hack it. But I doubt they made it that easy. It's not like an INI file with some setting for showing it.
