2000 Toyota Tundra wiring help! VSS Illum Backup
By cbr1000x · Apr 07, 2007in Problems/Troubleshooting💬 5 posts👁️ 2,549 views
Posted Apr 07, 2007 · 00:20 UTC#1
Hello everyone. I am a first time poster. I just bought a Z1 and am looking forward to hooking it up. I have a 2000 Toyota Tundra 4wd limited. Unfortunately there is no information on where to find the VSS and backup wires and Pioneer told me to go and bother someone else. I did a search and found a string for a 2006 tundra double cab with info on these hookups but I am not sure that they are the same for my year and model. Also, for the flash trick to work, do I hook the illum wire to the park lights or high beam lights? Thanks in advance!
Posted Apr 07, 2007 · 00:32 UTC#2
Speed Sense green/orange instrument cluster, brn plug
or
Speed Sense GREEN/ORANGE (AC) PIN 15 AT BCM
Reverse Lights RED/BLACK (+) 5 PIN WHT. CONN. in kick panel
Posted Apr 07, 2007 · 02:02 UTC#3
The illumination wire will be in the radio harness. The wire harness you buy will have a pin for the ilumination wire.
Posted Apr 07, 2007 · 02:19 UTC#4
Thanks for all of the help guys. About the illum wire hookup, according to my wiring diagram of the radio there is no illumination wire. Should I hook it to the running lights or the high beam lights for quick flash? What is the illumination hook up for?
Posted Apr 07, 2007 · 02:31 UTC#5
There is an illumination wire at the radio harness.
