Navigation Arrow shows wrong direction on screen
By rocky2985 · Jun 11, 2006in Problems/Troubleshooting💬 8 posts👁️ 2,008 views
Posted Jun 11, 2006 · 07:00 UTC#1
Hey guys, i just installed my unit like a few days ago and when i drive it shows the arrow part of it like oppositly. It thinks i am reversing or something. Is it how the sensor is put?
Where is the best place to but it. I have it on the back dash, should i mount it on the front dash?
Any ideas and answer help
Thanks in advance
Posted Jun 11, 2006 · 12:03 UTC#2
Thanks in advance
Rotate the GPS antenna 180 degrees. I think it's getting confused.
No just kidding, don't do that.
I think that the only way the arrow will point a different way than what you are traveling is that you have your reverse light sense hooked up and in the head unit it's programmed backwards. The head unit is smart enough to program it to see 12V as "reverse" or Ground as "reverse". My guess is that you have the sense wire connected (or not I guess) and that is programmed backwards.
For the life of me I can't find it in the book. And it's cold outside right now and I just got up so I don't want to walk out to the truck. But look around in the settings for "low" or "high" being the signal for backing up. I would guess yours is backwards. Or if you didn't set it, just cange it to the otherway.
Posted Jun 11, 2006 · 12:12 UTC#3
Oh, found it, page 154 in the operation manual. System settings, then Camera Input. Look for the polarity section. If that's set up backwards it might thing you are going backwards all the time. If you have no backup camera, it might let you go "backwards" in the GPS but if you had a camera hooked up, it might be showing you what's behind you all the time.
If that's not it, then I got nothing. It sounds very weird.
Posted Jun 12, 2006 · 03:29 UTC#4
I've seen one other case of this, but not with a new unit. A user switched his unit from one car to another and in doing so the orientation of the unit changed slightly. In those cases you have to hard reset the unit and clear all 3d data.
Posted Jun 12, 2006 · 14:10 UTC#5
I had something similar with my D1, but I went from having the VSS hooked up with full 3D, then unhooked the VSS and went back to Hybrid. It was all kinds of confused, so I had to go into the settings and reset it to Hybrid from the 3D setting. Try that.
Posted Jun 13, 2006 · 06:03 UTC#6
had the same problem simply go to settings - modify corrent location and setup rotate the arrow the way you need -- page 98
Posted Jun 13, 2006 · 12:26 UTC#7
Just out of curiosity, why would you unhook VSS?
Posted Jun 14, 2006 · 02:55 UTC#8
Also try to reset the deck, by using the reset button.
