Getting music on to my Z1's hard drive
By cbr1000x · Apr 07, 2007in General💬 14 posts👁️ 2,091 views
Posted Apr 07, 2007 · 16:21 UTC#1
Not sure where to post this. I want to put my music (in mp3 format) on my Z1's hard drive. I know that the Z1 will not allow this. Without having to burn 100s of audio CDs from my mp3 files, is there any way to make an "audio DVD" from my MP3 files? I have Nero 6 and in DVD mode, it will not allow me to make an audio DVD. Anyone have any insight on how to do this more efficiently? Thanks a bunch in advance. I am learning so much from these forums.
Posted Apr 08, 2007 · 02:11 UTC#2
Nero 6 doesnt allow you do to audio DVDs. I personally use roxio to make audio dvds. Still not as good as an mp3 cd, but at least you can reduce the number of CDs/discs you burn by about 6 times
Posted Apr 09, 2007 · 15:26 UTC#3
Why isn't it as good as a mp3 cd? It definitely holds more music.
Posted Apr 10, 2007 · 02:40 UTC#4
Roxio what? EZ CD creator? It allows the ability to make music DVD's that are transferrable to the hard drive?
Posted Apr 10, 2007 · 04:02 UTC#5
i think an mp3 cd still holds more music than an audio (wav files) dvd, or should be about equivalent depending on how big your mp3s are.
They let you make audio dvds (mp3s are converted to wav files), which are the only type able to be transferred to your Z1 hard drive.
Posted Apr 10, 2007 · 13:17 UTC#6
So mp3's can't be burned to a dvd to make a data cd just like a cd-r full of mp3's? I just bought a d3 and dvd burner so I guess I'll find out on my own.
Posted Apr 10, 2007 · 13:53 UTC#7
The z2 cannot play data dvds (mp3s). Only the D3 can do that. Sucks I know, but that is the way it is.,
Posted Apr 17, 2007 · 16:45 UTC#8
I'm trying to do the same...and use up the 10GB HHD left, but most of my music are MP3 files. Can Gracenotes pick-up the artist and titles if you load "audio DVDs"?
Posted Apr 17, 2007 · 23:09 UTC#9
I got nero 6.6 with my dvd drive and that says mp3 dvd.
Posted Apr 18, 2007 · 05:18 UTC#10
Nope, Nero 6 won't do it (at least 6.3 doesn't). I have heard that Roxio will, though. If 6.6 does, then likely 7 will too.
That being said, once you make an audio DVD, I think that you should be able to include CD TEXT, that is artist/title information right on to the DVD. This way the Z1 can read the info directly from the DVD. At least it works this way using a CD.
Another alternative is to use a CD-RW and just re-record. Still long, but you aren't wasting a bunch of CDs.
Posted Apr 18, 2007 · 14:41 UTC#11
i have nero 6 something... i made a data mode DVD and dropped my mp3's right on there no problems
Posted Apr 18, 2007 · 18:59 UTC#12
You also have a D3. The Z series is different.
Posted Apr 18, 2007 · 22:22 UTC#13
Ok, I have come to the realization that mp3's can not be put on the harddrive and have started burning audio CDs and loading them into the Z1. MAN THIS THING HOLDS A LOT OF MUSIC! I have 30 CDs in already and only 25% of the 10 gigs used. Here is my new dihlema... I want to keep all of my 80's, dance, rap etc in each of there own albums. Right now I have 80's A-C, D-G etc...as much as my music CD will hold. I want to combine all to just '80s'. Any way to do this so I dont have to scroll through 100 albums on the library? This is a great unit but annoying in some ways with the limitations. I would separate them by Genre but they are limited as well. Thanks for the help but I have a feeling that I will be dissapointed with the answer, darn Pioneer engineers!
Posted Apr 19, 2007 · 22:32 UTC#14
Group them into playlists ("My Favorites").
