Bypass problems still!
By jazzmainian Devil · Apr 07, 2007in Hacks/Mods💬 8 posts👁️ 2,523 views
Posted Apr 07, 2007 · 18:26 UTC#1
I did the bypass in my new 07 Silverado. Video works good but when I start to move the vehicle I get the door chimes from hell. Did I do something wrong?
Posted Apr 07, 2007 · 18:30 UTC#2
Did you use an adaptor when installing your deck?
Posted Apr 07, 2007 · 18:44 UTC#3
Yes I used the gm module
Posted Apr 09, 2007 · 01:29 UTC#4
My H2 did that when I put the parking brake on (one click) and drove it. When the bypass is done right, the D3 thinks the parking brake is always on. It sounds like your truck thinks the parking brake is on too.
Posted Apr 09, 2007 · 02:14 UTC#5
did you try disconnecting the bypass and see if it still makes the chime
Posted Apr 09, 2007 · 05:53 UTC#6
the GM Module? Which one? Scosche? Metra? Which part number? Double check all the wiring on it and make sure you didn't short out a wrong wire. I know through the data bus you can get reverse, VSS, parking brake, and many others... just be sure you didn't ground the VEHICLES parking brake wire or anything else
Posted May 15, 2007 · 23:18 UTC#7
If the AVIC's light green wire is connected to the parking brake and ground at the same time, the truck will think the parking brake is set and will produce the chime. Make sure you disconnected the AVIC's parking brake wire from the trucks parking brake and connect it directly to gound. You will also need to reset the AVIC to get rid of the parking brake improperly connected warning.
Posted May 21, 2007 · 14:49 UTC#8
shotgun_customs
FTFMW! :D
