No connector in "connector 2" How to do 07/06 bypa
By Autobahn · Apr 07, 2007in Problems/Troubleshooting💬 4 posts👁️ 721 views
Posted Apr 07, 2007 · 21:53 UTC#1
I have had my unit for over a year and always flashed my headlights to do the bypass. However I have now done the Bluetooth upgrade so I am trying to do the 07/06 bypass but discovered there is no connector whatsoever plugged into the "connector 2" slot. Where do I create the other ground? Please help.
Thank you.
P.S. I have never had any kinds of problems with my unit.
Posted Apr 07, 2007 · 22:36 UTC#2
Order the connector from Pioneer, problem solved. Or go back to whoever installed it and ask for it back. They all came with one
Posted Apr 07, 2007 · 23:37 UTC#3
I found it, thanks!
Ducatiboy -
It might be a good idea to put a little note in the Smin webpage about this. I'm sure there are a lot of people who didn't have the things installed which are connected to connector two. Then again maybe I'm just slow. Although it has been a year since I installed my Z1.
cheers everyone...!
Posted Apr 13, 2007 · 16:36 UTC#4
I had a hard time at first getting the wire to stay in the connector. I finally used some silicon caulking to get it to stay in there. After that it worked like a charm and my Z1 install is now complete! Everything works beautifully from the Bluetooth to the iPod to the bypass. Hopefully I will never have to pull out my Z1 again!
