Ground question (Mazda3 related)
By zoomzoom · Apr 08, 2007in Hacks/Mods💬 5 posts👁️ 1,552 views
Posted Apr 08, 2007 · 11:37 UTC#1
The harness I got for my Mazda3 2007 has a ground on it. I cut off the spade connector on the radio harness (d3) and spliced it with the harness' ground.
Is this okay or should I have grounded the spade and left the car harness ground alone?
My DVDs still dont play past 15 mph AND I have the improper ground warning so I'm going to go thru all the connections tomorrow and figure it all out, just looking for more input from you more experienced d3 users :).
Thanks for the help in advance.
Posted Apr 08, 2007 · 11:44 UTC#2
the ground wire in your harness is fine, but you have to do the bypass for your video to work
Posted Apr 08, 2007 · 13:46 UTC#3
Ty for the reply. I did the bypass but a wire isn't connecting or grounding properly, probably the mute wire as I wasn't too confident in it being secure the way I inserted it. Gonna redo it with all solder (hate the butt connectors) and I'll post back.
Thanks again
Posted Apr 08, 2007 · 14:04 UTC#4
just make sure its clicked all the way in, and in the reght pin
Posted Apr 09, 2007 · 14:44 UTC#5
I have a mazda 3 aswell and i grounded the mute wire properly but since the space in our dash is so small that is puts stress on the wire and pulls it out. I think i need a new pin for my harness.
